Machine Vision
3D camera from SoftKinetic
P.S.: Do you have access to the raw IR image data?
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 11 of 15
(3,406 Views)
Thanks, I will look into it!
No, I only have access to the processed data i.e. a table, where each value is a representation of the depth of the pixel in question.
Message 12 of 15
(3,403 Views)
Also, the sensor should be calibrated, so the intrinsic calibration parameters should be located somewhere!
K
Message 13 of 15
(3,401 Views)
Will the pin hole model also work on surfaces with a curvature?
For instance if I want to measure the cirkumference of a cylinder?
Message 14 of 15
(3,389 Views)
The camera model is simply a way to map the 3d coordinate onto a 2d image plane. If you account for the distortion, the principal point offset and focal length in both directions, accurate measurements can be performed.
Measuring the circumference (even half circumference) of a cylinder would be impossible with one static 3d camera because of the occlusions and not covering the neccessary measuring area.
K
Message 15 of 15
(3,373 Views)
