Machine Vision
8-Tap FPGA Centroiding
I successfully converted the 1-Tap  Frame Trigger example to use with an 8-Tap Camera.  Now I am trying to do the same with the 1-Tap 8-Bit Centroiding example, but I am stuck.  Has anyone successfully converted the 1-Tap Centroiding example to use with a 8-tap Camera (or with any multi tap camera)?
P.S.  I want the the centroid processing to be done on the FPGA and not the host.
Thanks in advance.
Message 1 of 8
(6,720 Views)
Hi altran,
What steps have you taken so far to try to use the 1-tap 8 bit centroid example? Where are you stuck?
Message 2 of 8
(6,610 Views)
Hi Robert,
I tried to copy the 1-Tap Centroiding and "arrange" it for an 8-Tap Centroiding, but the Centroiding FPGA VI in the 1-Tap supports only 1 Pixel at a time.  I am not sure how I would proceed to process 8 pixels at a time as opposed to 1 pixel.
Message 3 of 8
(6,604 Views)
Are you able to configure your camera to 1 tap and then use the VI? To my understanding, you can either change the camera mode to 1 tap and try to use the VI or you would need to write some new FPGA code to use the 8 tap.
Message 4 of 8
(6,564 Views)
Hi Robert,
Yes, I have been able to use 1-Tap mode.  My question is if there is anyone that could help me convert the 1-Tap VI Centroid to use with an 8-Tap camera.  I am having issues trying to process 8 parallel pixels as opposed to 1 pixel.
Message 5 of 8
(6,557 Views)
I see. I have never done it personally, but I found this KB: http://digital.ni.com/public.nsf/allkb/EA1727D8D620B81F8625797B0072257C You may have already seen it but it describes how to change a different example from 1tap to 2 tap configuration. Is that helpful?
Message 6 of 8
(6,517 Views)
Yes, I've seen that.
The problem is that in the example, the Centroiding VI is capable of only processing 1 pixel at a time.  I was hoping that there was somebody who was successful in converting this to a multi tap centroid.
thanks
Message 7 of 8
(6,513 Views)
As part of VDM 2016 offering you can call into a 8 tap Centroid on FPGA
Message 8 of 8
(5,584 Views)
