Machine Vision
ADV Toolkit (Imageprocessing on NVidia GPU)
@rfdfdgf wrote:
I want to congratulate you for this great toolkit, is exactly what I needed.
I have just bought an GTS450 videocard to use it in my image processing projects.
I have checked the NVidia website for how many Processor Cores this videocard has, it says 192.
But when I try you're example it says number of streaming processors = 4 !!!
Hi, Andrej,
Its seems to be OK. You probably confused SMs (streaming multiprocessors) with SPs (shader processors or CUDA Cores). As far as I know, your GTS 450 based on GF 106 architecture and on this architecture each streaming multiprocessor contains 48 SPs. So, 192/48 = 4. SMs are really the basic execution unit in NVIDIA hardware.
Hope it helps for understanding,
Andrey.
Message 11 of 34
(5,695 Views)
Andrey I must confess you that I simply love a straight answer.
Thank you very much.
I hope the shop will accept the return in exchange of a Quadro FX380 video card 🙂
If you're kind how many SMs and SPs have the 9600 video card? Where can I find all this data about CUDA video cards?
Once again thank you for the great job.
Best Regards,
Andrei
Message 12 of 34
(5,692 Views)
On all cards other than Fermi, a streaming multiprocessor is a cluster of 8 scalar cores. Therefore I have 8 SMs (and totally 64 SPs). But from performance point of view GTS 450 should be much faster than 9600 GT (even with less SMs).
You can get tech specs from nvidia web site (search for each card), or from wikipedia:
http://en.wikipedia.org/wiki/GeForce_400_Series
http://en.wikipedia.org/wiki/Nvidia_Quadro
http://en.wikipedia.org/wiki/GeForce_9_Series
http://en.wikipedia.org/wiki/CUDA
Andrey.
Message 13 of 34
(5,689 Views)
Hello everyone,
                         I am facing an issue when I am trying to build an executable with the toolkit on my LabVIEW 2010. It builds the executable successfully, but the only problem being when I run the exe. The VI runs perfectly fine with now warnings/ errors. But the exe throws out dll's missing errors namely freeimage.dll and advision.dll missing. I was able to find the feeimage.dll but unable to find the later one. Could someone help me out with this if there is a workaround for the same and if any one has encountered the same problem?
Thanking you in anticipation.
Shreyas H
Shreyas Hebbare
Shreyas Technologies
India
Message 14 of 34
(5,489 Views)
I got your code to work! Finally a simple way of using IMAQ with the GPU. If you could post the source code to your DLL files, that would help me a lot in my goal to start writing my own image processing filters.
Cheers,
Bob
Message 15 of 34
(5,422 Views)
Is it possible that this toolset could be extended to stream to video formats like avi?  One of the great bottlenecks I have found
in IMAQ is the performance limitations of the AVI Write frame.
Message 16 of 34
(5,388 Views)
Yes, there als AVI functions based on OpenCV VideoWriter, which can be better in some cases.
You must know FourCC code for your codec.
For example, writing video with xvid codec looks like that:
(Some users reported that this code caused troubles on exit)
Message 17 of 34
(5,377 Views)
Great Job,
How about missing AVI libraries? It is possible I might missing someting...
Looking forward to test it with high speed GigE cams.
-Artur
Message 18 of 34
(5,206 Views)
AVI's library identified,
No more help required, thank you
-Artur
Message 19 of 34
(5,188 Views)
Congratulation for this toolkit! This is exactly what I needed and it's, in my opinion, easier to use than the GPU analysis toolkit!
Any chance you've been updating it since 2010?
regards,
Message 20 of 34
(5,146 Views)
