Machine Vision
AVI Video frames
I am trying to output the avi video, one frame at a time. But I am only getting the last image. I am attaching my code. It is a one part of my big project. Can somebody help me in debugging my code and guide me how I can fix the above mentioned issue.
Message 1 of 9
(6,220 Views)
your VI "Init data transmission" works fine on its own to read an AVI file and display frame per frame. I don't really understand the main VI... Why are you integration an FGV?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 9
(6,212 Views)
As I already mentioned it is part of big project. Please see this post. I am trying to tranmit AVI video between NI-USRPs. The modulation part of my code is fine and does not have any problem. But I have problem in my code where I am reading avi video and converting it in to bits. It only outputs last image so the code that is creating the images needs to be debugged.
So that is why I am using FGV. Can you please guide me how to fix this problem.
Message 3 of 9
(6,207 Views)
Epictetus
Antoine Chalons
Message 4 of 9
(6,187 Views)
hope this helps
Epictetus
Antoine Chalons
Message 5 of 9
(6,186 Views)
Many thanks for your reply and guide but If you look at this post the first code which I attached in that post has similar thing which you explained in your video. I also did not use any FGV in that code.  But the thing is that with my main USRP code after getting output array of the avi video when I am enqueueue elements in another for loop I do not get any data there until the avi video for loop finishes. When avi video file for loop finishes I only get the last frame array elements for enqueue element vi. So that is my problem. I hope you understand it now better what exactly the problem is. If you can guide me how to fix this issue I would be really glad.
Many thanks once again.
Message 6 of 9
(6,175 Views)
Did you look at my last post. Do you any suggestions how can I fix this issue. Many thanks once again for your guidance.
Message 7 of 9
(6,134 Views)
By the way I edited my code. I am attaching the new code. It works but only partially. It reads only few frames of avi video and generate output array and also enqueue the elements properly but after few frames it stops can you please have a look at it and guide me how to fix it.
Message 8 of 9
(6,118 Views)
you set a max queue size at 1000 elements, as noone is emptying the queue, when it is full the enqueue primitive is blocking your code.
hope this helps
Epictetus
Antoine Chalons
Message 9 of 9
(6,100 Views)
