Machine Vision
AVI creation with 8-bit Image Type specified
I am NOT able to create an AVI using 8-bit Image Type (specified for IMAQ create)
I am able to create AVI using RGB Image Type (specified for IMAQ create)
The help for IMAQ AVI Write Frame states that "This image must be either an 8-bit or RGB image."
Why does this not work for 8-bit image type. Using LV71, Vision7.
Don
(3,774 Views)
Hi Don,
Here is a KB that should answer your question:
http://digital.ni.com/public.nsf/websearch/4FAC615B62919BA5C1256ED00046997A?OpenDocument
Regards
Dan Q
(3,774 Views)
Hi Dan:
This does not answer my question because
1) I am using 8-bit image type that the AVI Write Help tells me is valid (8-bit image frame shows up fine in image control)
2) I don't get an error (which is what your KB talks about). I just get a messed up .avi that when played is all garbled and looks nothing like the image frames.
The code is very simple, I just followed the examples. Does not work with 8-bit image type. I am not acquiring images for this particular work. I am converting 8-bit normalized 2d arrays to IMAQ image types. CAn send you a simple version of the code if you want but it just follows the example for creating AVI (except I tried 8-bit which does not work whereas RGB image type worked). Can you check on this? AGain, you w
ill not get an error message but the AVI file will be strange.
Don
(3,774 Views)
Don -
A copy of the code would be helpful, as well as the images you used to create the AVI and the garbled AVI itself.
Thanks!
Greg Stoll
IMAQ R & D
Greg Stoll
LabVIEW R&D
(3,774 Views)
Here is basic code including resulting AVI...Don
(3,774 Views)
Don -
I was able to reproduce this behavior on my machine with Vision 7.0. This is a bug, and has been fixed in Vision 7.1.
Greg Stoll
IMAQ R & D
Greg Stoll
LabVIEW R&D
(3,774 Views)
