Machine Vision
AVT Stingray firewire camera with windows 7 64bit
I have installed Labview 2009 and vision acqusition software in a system running windows 7 64 bit professional version.  When I connect the AVT Stingray camera to the system with 1394b hardware board, MAX (4.6.2) does not see the camera.  When I first open the MAX, I show the Legacy 1394 driver show up under the devices and interfaces and then disappear within few second.  It does not show up again when I connect again.  When I loaded grab.vi example and ran it with camera id cam0, camera start taking images.  It means camera is working with the currently installed IMAQ drivers.  How do I get the camera to show up on the MAX?  I need to change the setting on the camera using MAX.
Thanks for your help.
Sam
(3,912 Views)
Hello Tenna,
Which version of NI-IMAQdx do you have installed?
For Windows 7, you would need to have NI-IMAQdx 3.4.
You can download Vision Acquisition Software 2009 that will install NI-IMAQdx 3.4 here
NI Vision Acquisition Software 2009.08 - Windows 2000/7 64 bit/XP/Vista/Vista x64/7 x86 - 2009
http://joule.ni.com/nidu/cds/view/p/id/1393/lang/en
Andy Chang
(3,899 Views)
