Machine Vision
Access h.264 encoded video data stream from USB webcam
I need help in a video communications application. In my project, I need to acquire video with a USB webcam, modulate and transmit data through some medium and then receive and demodulate and display received video. I can do this with IMAQdx-Grab with decompressed image frame pixel values since IMAQdx automatically decodes while grabbing. However, using these decoded pixel values means converting each frame to a vector of bits and modulating, transmitting, demodulating these vectors, and it takes too much bandwidth and processing time. My priority is getting as close to real-time as possible with limited available bandwidth. Hence, I'd like to access encoded video data stream instead of pixel values and transmit these instead of the full frame pixel values. I know Logitech c925e has on-board h.254 AVC and SVC compression and provides encoded stream. So, my question is, is there a way to access this data stream using Labview with IMAQdx or any other driver? And similarly, is it possible to decode the received bitstream and display the decoded video frames?
(2,682 Views)
Hi gt,
I noticed that you opened up a Service Request with our Applications Engineering department. If you're able to find additional information from them, go ahead and update this post with any solutions.
Madison T
(2,637 Views)
