Machine Vision
Access to correction table?
In order to correct for a lens distortion, I am acquiring an image of a calibration grid, using IMAQ Learn Calibration Template with Learn Correction Table? set to True to characterize the distortion, and then using the calibrated image to correct subsequently acquired images using IMAQ Correct Calibrated Image.  This process works fine, but I would like to have access to the correction table values that are stored with the calibrated image.  Does anyone know how to access this table?
(3,176 Views)
Hello cegar. It does not seem that retrieving this correction table is possible. All of the information that is avialable about the calibration can be retrieved from the Get Calibration Info.vi. This has some valuable information including the information outputted via the Calibration Learn Setup output terminal and the Grid Descriptor ouput terminal. I hope this helps answer your question!
Brian
(3,161 Views)
