Machine Vision
Acquire 2D image from Line Scan Camera
Hi all,
I am setting up a line scan camera with PCIE1433 and CameraLink interface. The line scan camera is a 4096 line, and after settling up I was able to show  the continuous single line inside the NI MAX. I can set the camera file parameter to change picture height to 1000, 100, 1 according to what i want, and here are some interesting questions as follow: If I set the picture height to 100, does that means right now I am acquiring 100 lines and displaying it as a 4096*100 frame? Another question is: Let's say the line scan camera has line rate at 1k and I set as 100 lines for heights on the MAX, does that mean the frame rate become 10?
Thank you for the replay,
Louis
(5,163 Views)
You are correct on both.  100 lines creates a 4096*100 frame, and would make the frame rate 10 fps if the line rate is 1000. (1000/100 = 10).
Bruce
Bruce Ammons
Ammons Engineering
(5,152 Views)
Hmm thats interesting. Lets say if i want relatively bigger picture height like 8000 with 1k line rate and i want to grab a frame of it, thus i have to wait for 8 seconds for a single frame. I tried to add frame timeout to greater than 8 second at MAX but for some reason if the frame rate becomes a such smaller number the MAX will not response...
(5,146 Views)
In this case, I would acquire frames no larger than 1000 lines to avoid timeout issues.  You can always combine multiple images into a single image after the acquisition. This also gives you the option to cancel the acquisition before the entire thing completes.  Eight seconds is a very long time to wait for an acquisition.
Bruce
Bruce Ammons
Ammons Engineering
(5,120 Views)
