Machine Vision
Acquire image in Vision builder 6.1 with PCI 1410?
I've been trying to setup my newly acquired PCI 1410 framegrabber using an RS-170 standard camera. I can see the image in the measurement and automation explorer but I cannot acquire the image onto the Vision Builder 6.1 that I am using.
(2,921 Views)
Hi Varkey,
As we discussed earlier, Vision Builder 6.1 is no longer under development. Vision Builder 6.1 supports the following framegrabbers:
  1. PCI/PXI-1407
  2. PCI/PXI-1408
  3. PCI/PXI-1409
  4. PCI/PXI-1411
  5. PCI/PXI-1422
  6. PCI-1424
  7. PCI-1428
There are two products that have similar functionality to Vision Builder and have support the PCI-1410.
Vision Builder for Automated Inspection is a standalone product that is intended for running inspections on many products. It has the ability to convert inspection scripts into LabVIEW code should this be needed.
Vision Assistant is a tool to help develop vision routines. Unlike Vision Builder for Automated Inspection, it is not intended as a stand alone program for running many tests; however, it is an easy and convenient way to develop a vision routine and then import it into Labview.
(2,902 Views)
