Machine Vision
Acquire two images from one snap: gige camera teledyne
I need to load 34 images and inspect them all sequentially, outputting the results to an array. That part works OK, the problem is selecting the images. They are all in the same folder but I can't find a way to select and load them all. Instead I have to select one and hit 'OK' then hit the next.
I'm sure there must be an easier way. I just want to select all the files in the folder at once, as shown below.
Thanks in advance.
(2,875 Views)
Accepted by topic author another_novice
use this with one for loop to solve it
(2,841 Views)
Works like a dream! Thank you!
(2,836 Views)
