Machine Vision
Acquiring Images using the USB port
I want to acquire Images using the USB port of the PC. Is it possible to acquire images using the USB port and analyze the image using IMAQ library. If we use the USB port direct then we may not need the IMAQ vision acquisition card.
(3,980 Views)
It is possible to acquire images using other sources and process them using the IMAQ Vision library. The trick is obtain LabVIEW drivers for doing the acquisition and converting the image format to the IMAQ format. For a USB camera, there are probably a couple of options available. Check recent items for discussion of the possible methods.
Bruce
Bruce Ammons
Ammons Engineering
(3,980 Views)
hhjjj wrote in message news:<5065000000080000009B7E0000-1042324653000@exchange.ni.com>...
You can use IVision if you want to have more control over your camera.
check out at:
http://www.geocities.com/irene_he/IVision.html
Or there are other free vis for USB webcam too, you may find it in the
discussion forum.
Irene
(3,980 Views)
I thnks it is possible.
I use USB PC Camera and capture the image by 'VFW' fucntions.
you must know about what is the 'VFW'.
and the last things to do is just conversion
VFW type image buffer to NI type 'Image *' buffer.
(3,980 Views)
Dear Sir,
I have a LogiTech QuickCam which uses the USB port for Image Acquisition. It would be nice if you could please provide me the details of the how to go ahead and acquire image using the USB port.My camera is also a webcam which we want to use for image acquisition.Please provide me the details.
Thanx
hhjj
(3,980 Views)
Try Irene's drivers (see previous answer above), or Peter Parente's webcam drivers (www.mindofpete.org).
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
International Voicemail & Fax: +61 2 8080 8132
Australian Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsib
ility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,980 Views)
