Machine Vision
Acquisition Issues with GigE Camera
I'm trying to acquire signal from a STC-SC133POEHS GigE Camera from Omron Sentortech. The camera data are 1280 x 966 bayer RG8 - 40 fps.
I was unable to grab images using the IMAQ-SX driver. I used the Video Acquisition function and tried only to acquire and visualize images without any elaboration. THe camera work properly under NI-MAX configurator but shows sistematic timeout error -1074360293 if used in running VI.
I tried to change several configuration parameters but the timeout alway occurs.
Thaks for help.
PAOLO CASTELLI
(2,234 Views)
You can try grab "Grab and Attributes Setup.vi" in example path C:\Program Files\National Instruments\LabVIEW 2018\examples\Vision Acquisition\NI-IMAQdx\High Level.
(2,174 Views)
