Machine Vision
Adding Attributes to the IMAQdx Class
I've got a subVI to modify several camera attributes; however, none of these attributes are included in the IMAQdx class.  Consequently, I've got to use a doubly-long property node where for every value I want to display or change, I have to first write that attribute as the current attribute.  Is there a way to add attributes to the class so they'll populate in the property node list of camera attributes?
(4,960 Views)
Accepted by topic author brendan111
Sorry, no, this is not possible today. We are actively looking at API improvements to address this sort of issue in future versions though. Out of curiousity, are the properties youj are wanting to change vendor-specific or are the common features already specified by the Standard Features Naming Convention (http://www.emva.org/cms/upload/Standards/GenICam_Downloads/GenICam_SFNC_2_2.pdf)
Eric
(4,955 Views)
They're all vendor-specific.  Still no problem setting them to current attribute and modifying same though.
(4,952 Views)
