Machine Vision
Angle value in results of IMAQ Find Straight Edges 3 VI
Hello everyone,
I'm working on a project for automated machine vision system using NI Vision.
One of the tasks is detect straight edge of the object. So, I'm using IMAQ Find Straight Edges 3 VI and I have question about results of this function.
For example, if I set method type of the detecting edge to "First Edge Rake" - function return explainable results, which are consistent with function description. But, if I set method type to "Hough Edge Rake", function returns strange value of edge angle. Moreover, if I make a little change in orientation settings, function returnes the same edge, but the differ angle in results.
So, could anybody explain what angle returned using Hough Edge Rake method?
(1,742 Views)
Thanks everyone for the help,
I found solution. Sorry for a long response.
So, for Hough Edge Rake method: angle value in results is returning relatively to expected orientation of line. For others methods - relatively to image axis.
You can use this code sample to fix results for uniform representation.
(1,677 Views)
Another question is "Min. Points (%)" parameter. In description said: Min. Points (%) specifies the minimum number for points as a percentage of the number of search lines that need to be included in the detected straight edge. The default is 25%.
But, this parameter works only for Hough Edge Rake method 😉
For example, If I set First Edge Rake (0) method, function can return line based on less number of points, than assigned in Min. Points (%) parameter.
So, it would be wonderful, if NI will carefully check and update description for their functions of NI Vision Development Module.
(1,673 Views)
