Machine Vision
Attachment Gray Morphological Reconstruction H-Dome Example.vi ‏75 KB
please,,, can any one attach the mentioned example in labview 2009????,,, it looks useful for me ,,but i can't access it because of it's version...
thanks
(4,192 Views)
I think that example (and the VI it uses) was added in Vision 2011, so unless you have that (or later) version, then you wouldn't be able to run it anyway.  If you do have Vision 2011, then it should be already there in your LabVIEW Examples directory.
(4,185 Views)
