Machine Vision
Automatic selection of an ispection of BVAI ver 2.0
I wish to select the ispection of VBAI ver2.0 to run automatically, moving the digital imput of the PC-DIO-24.
Do I need an LV application or it's possible to do it directly?
(2,964 Views)
I have good news and bad news.
Good News: you can set DIO inputs to select which inspection to run with just Vision Builder AI 2.0, so there is no LabVIEW program to write.
Bad News: The product selection lines only work with the Compact Vision System. So this feature only works with Vision Builder running on a Compact Vision System.
If you don't have a Compact Vision System, your best bet may be to have Vision Builder AI create LabVIEW code for you, then use LabVIEW to select which inspection to run.
Let me know if I can help.
Kyle V
(2,964 Views)
