Machine Vision
Automatically populate table with all step results in vision builder
When creating a new custom inspection interface in Vision Builder does anyone know how to automatically populate a table with all step results?
(2,697 Views)
Hi Telecentric,
The automatically populating the table feature is only available with the default inspection interface. However, it is possible to implement in a similar table in a custom inspection interface.
This forum post has a discussion on how the user implemented such a table
https://forums.ni.com/t5/Machine-Vision/vision-builder-default-inspection-UI-doesn-t-work/td-p/25634...
Jiwhan S.
Technical Support Engineer
(2,651 Views)
The problem is to dynamically handle getting all the results as more steps are added as like int the default inspection interface.
(2,649 Views)
Hi Telecentric,
As Brad mentioned in the previous post, there isn't an easy way to do this dynamically. However, he included recommendations under step "B" from this forum that you should consider (I linked to that post).
https://forums.ni.com/t5/Machine-Vision/vision-builder-default-inspection-UI-doesn-t-work/m-p/256785...
It will also help users provide recommendations if you elaborate on why you want to do this dynamically. Images of your current situation are usually helpful.
Best,
Ben
(2,632 Views)
