Machine Vision
BCG Lookup showing Error
Hey Guys
         When I tried to Execute BCG Lookup on a complex image , the VI shows error. Does anyone know how to get rid of it.
    Thanks in advance.
(5,118 Views)
complex single is 8 bytes of data, whereas the BCG lookup only accepts 1 byte datatypes. I would guess that this is the problem, but the error of datatype mismatch is usually reported instead of the error you've posted in the screenshot.
Also, if I see correctly, the image reference passed to the BCG lookup "src" has no image (I cannot see behind the error).
P.S. Check the function's help in order to see what datatypes can be passed to it.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,115 Views)
