Machine Vision
Bad First Image on Vision Assistant using IEEE1394
While acquiring images in Vision Assistant or Vision Acquisition in labview, the first image is always bad (see attached) and then I get good images. I am using IEEE 1394 camera MC-F433C. This issue arises with all the four cameras I've tried so the camera doesn't seem to be defective.
Please help
(4,133 Views)
Frankly I dont see the difference between the two images.
(4,121 Views)
First explain what makes the first image bad, since it looks almost identical to the good image.
Do you have a camera that requires you to throw out the first image?  Some cameras never take a good first image, and there is a switch in MAX to compensate for that.  Something like "Ignore first image".
Bruce
Bruce Ammons
Ammons Engineering
(4,118 Views)
sorry! I didn't name them right, here's the bad image file.
(4,089 Views)
I apologize that it still exists and the documentation may still list it, but this feature actually has no effect in the IMAQdx driver. It was broken in earlier releases and any functionality it had was since removed. You would have to manually ignore the first frame in your code, or use a different camera that does not return a corrupt first frame.
Eric
(4,080 Views)
The properties menu of VISION ACQUISITION, there is a drop box: Acquisition Attributes and it has the option of Ignore First Frame. I have that set as TRUE but still same problem.
do i have to program it using IMAQ VIs?
(4,076 Views)
