Machine Vision
Balser USB3 color camera Timeout error
Balser acA200-165uc camera
Connected USB3.0 port
Opened in MAX
Keep getting this timeout error, sometimes 5 seconds, sometimes 15 seconds after 'Grab'
I searched this issue in the forum, and found many users encountered this exact error. Some suggested it was the USB3.0 host controller, other suggested limiting the bandwidth of the camera.
I reduced 'Device Link Throughput Limit' down a lot. It reduced the 'Frame Rate' from 94 down to 13, but still the Timeout error kept showing up.
I have another Balser camera, acA2000-165um, it works fine on this computer.
So it seems like a color Balser camera needs a better computer to run it?? If that is the case, I can switch.
Message 1 of 1
(650 Views)
