Machine Vision
Baumer camera slow to open session
I have Baymer PXU-120M.Q camera, but it is very slow to establish a session. MAX finds the camera and puts it on the list but every time it is selected in MAX or every time a vi opens a session to it, the delay is about 20-30 seconds. Once the session is opened the camera can be triggered and read just fine. Is there some configuration problem that could cause this delay? LabVIEW 2014
Message 1 of 10
(6,504 Views)
there is a vi icon to find camera information try to use to find information about the camera and try to use them in imaqdx property node to fix this problem
Message 2 of 10
(6,410 Views)
Sorry, I didn't get you. It will be good if you can post the small example code of what you are trying to tell.
I am using the Grab.vi example code of LabVIEW the first vi IMAQdx open camera.vi is taking 30seconds to execute and the rest is normal.
Message 3 of 10
(6,388 Views)
Can someone suggest me sollution to the problem mentioned?
I would appreciate any suggestions.....
Regards
A_SK
Message 4 of 10
(6,237 Views)
what about the max test does it work normal?
Message 5 of 10
(6,233 Views)
Thaks for the immediate reply....
In even NI MAX also camera takes 30seconds to open the camera.
Message 6 of 10
(6,229 Views)
ok try to repair your max and also
Imaq tool kit
if not yet fix
problem is based on max interface file to connect to camera
Message 7 of 10
(6,227 Views)
I have updated the IMAQdx and NI MAX to latest version, but still the problem exists. Is there any way i can control the interface file to connect to camera in NI MAX.
Message 8 of 10
(6,219 Views)
before you try to do that it is better ask people who use this camera if they have a same problem
also it is better to test your camera in other computer with other labview too
Message 9 of 10
(6,214 Views)
It will be good if anyone from NI Vision team answer to this question.
Message 10 of 10
(6,160 Views)
