Machine Vision
Bayers Decoder for IEEE 1394 camera
where can i get the Bayers Decoder software to convert the raw image details sent from the camera to RGB format?
(4,407 Views)
You can find a tutorial about Bayer decoding here and an example which does bayer decoding here [broken links removed]
Let me know if I can do anything else for you.
Amaury Rolin
NI Applications Engineer.
(4,405 Views)
Do you have access to the links ? Im having problems to access them.
If so, please send the information and example to armando@idea.com.mx
Im having the same problem converting from bayer to rgb
(4,387 Views)
Sorry the links don't work anymore.
The bayer tutorial is at:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/f50ff0fcd5b3f5e986256e8e0024fbf5?OpenDocument
Here is an example of Bayer Encoding.
This example shows how to use the Bayer encoding VIs in LabVIEW. It loads an image that was acquired with a Bayer Encoding camera. Use the parameter settings to setup the Look Up Table used for encoding the image. When satisfied, save the converted image.
Also, there is another example available: http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=CBF11A2C0A552EE3E034080020E74861&p_node=%20DZ52509&p_source=External
Let me know if this works for you - good luck on your project.
(4,366 Views)
Starting with NI-IMAQ for IEEE 1394 Cameras 2.0, bayer decoding is implemented by the driver. The bayer decoding parameters are configured in MAX and whenever you acquire an image, the decoded color image will be returned. No extra implementation required.
Hope this helps.
JohannS
(4,262 Views)
