Machine Vision
Binary image have white pixels after a Gradient In
When I process an image in NI Vision Assistant version 8.5.0 using the following steps:
2  Grayscale - Manual Threshold - Minimun 120
3  Binary -Basic Morphology - Gradient In (Structuring Element size 3x3, all sectors selected)
The resulting image shows several white pixels (grayscale intensity = 255)
Why the resulting image is not a binary image?
(4,614 Views)
you are right.I think it is showing single pixel gap alone.Just a guess.I tried varying the threshold but couldnt conclude on anything.
(4,465 Views)
Anyway nice observation
(4,464 Views)
Vision Assistant version 8.6.0 has the same problem.
(4,231 Views)
The NI Vision Concepts Manual says:
The internal edge subtracts the eroded image from its source image.
The remaining pixels correspond to the pixels eliminated by the erosion process.
If I is an image,
Internal edge (I) = I - erosion(I) = XOR (I, erosion (I))
Doing the operation I - erosion (I) do not appear white pixels, but using the Gradient In function the resulting image shows several white pixels.
(4,223 Views)
