Machine Vision
Bitmap of Grayscale images
hello everyone can anybody plz help me out.....i want to show grayscale images into Bitmap (0-7 bits). Is it possible to show garyscale image into bitmap 1 bit, 2bit,..upto...7bit image.
(3,856 Views)
Hello
you can convert directly an image from grayscale to bitmap by saving your grayscale image into .bmp
or you want to use labVIEW for this??
then I think you can do color thresholding of a grayscale image using NI vsion assistant.
(3,829 Views)
no need to do it using vision assistant.....i did it myself anyways thnks
(3,825 Views)
