Machine Vision
Bumblebee2 format 7 mode 3 pixel format: raw16 not available? Ni-imaqdx driver problem
I have problem with Bumblebee2 camera, i cannot choose the correct Pixel format: raw16, the only one pixel format available here in format 7 mode 3 is Bayer GR 16.
According to manual i need to set my camera to Format 7 mode 3. pixel format raw16 to get the data i need. I am using drivers provided with labview Ni-imaqdx IIDC digital camera.
(3,567 Views)
If you disable the Bayer decoding in IMAQdx, does it look right? It is possible the camera is identifying the pixel format still as bayer-encoded even though it is sending it in that raw 16-bit format with two 8-bit values per 16-bit "pixel".
Eric
(3,564 Views)
