Machine Vision
C# and C++中使用vision的bug
bug 1:
VAS2013生成的C#代码中:
        //  IVA_FindExtremeEdge
        //  Description:
        //      Finds the edge that is either closest or farthest from the start
        //      of a set of rake lines.
        //  Parameters:
        //      report          -   The rake report to process.
        //      findClosestEdge -   The direction of the main axis.
        //                          If false, report must contain both first and last
        //                          edge information
        //  Return Value:
        //      The extreme edge
        public static PointContour IVA_FindExtremeEdge(RakeReport report, bool findClosestEdge)
            Double extremeDistance;
            Double tempDistance;
            PointContour edge = new PointContour(0,0);
            // Determine if the function should process the first edges or the last edges array
            if (findClosestEdge)
                if (report.FirstEdges.Count > 0 )
                    extremeDistance = report.FirstEdges[0].Distance;
                    edge = report.FirstEdges[0].Position;
                    // Then find the edge that is closest to the boundary of the search area
                    for (int i = 1 ; i < report.FirstEdges.Count ; i++)
                        tempDistance = report.FirstEdges[i].Distance;
                        if (tempDistance < extremeDistance)
                            extremeDistance = tempDistance;
                            edge = report.FirstEdges[i].Position;
            else
                if( report.LastEdges.Count > 0 )
                    // First, intialize the value with the first edge in the array
                    extremeDistance = report.LastEdges[0].Distance;
                    edge = report.LastEdges[0].Position;
                    // Then find the edge that are closest to the boundary of the search area
                    for (int i = 1 ; i < report.LastEdges.Count ; i++ )
                        tempDistance = report.LastEdges[i].Distance;
                        if (tempDistance < extremeDistance)             //此处应为:if (tempDistance > extremeDistance)
                            edge = report.LastEdges[i].Position;
            return edge;
bug 2:
VAS2013生成的C++代码中:
findEdgeReport = imaqFindEdge2(image, roi, NULL, NULL, &findEdgeOptions, &straightEdgeOptions);
对于函数imaqFindEdge2的调用,经反复测试,存在内存泄漏的问题,对此函数的调用,会导致内存一直增长。
如有误请指教!
谢谢!
(5,242 Views)
Hi
    have you read the following attachments? I hope this can help
(5,209 Views)
对的,第一个问题我也发现了
(2,111 Views)
