Machine Vision
CAMFILE Changing
Hi ,
Using the PCIe 1430 card.
I need the possibility to swap my CAM file via code.
Anybody who knows how to do this using .NET code?
(3,387 Views)
Hey Thomas,
I do not have the code ready for use in .NET.
I can show you the steps to take in LabVIEW however, maybe this can get you going.
You will need to execute the same functions in the same order eventually.  Only the function names will be  slightly off in  the .NET programming environment.
Take a look at  the link below.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E89F56A4E034080020E74861&p_node=DZ52489&p_source=External
Wouter Van Hoof
(3,360 Views)
