Machine Vision
CAN I MAKE A PIXEL BY PIXEL PRINTING INDICATER USING LABVIEW? JUST WANT TO CHANGE COLOR OF ARRAY WITH WRITING PIXELS
THAT MEANS IT CONSIST OF A COLOR ARRAY. AND ON PROGRESSING PRINTING CURREPONDING RED PIXEL GET GREEN COLOR?
IamAKR
(5,140 Views)
Did you check IMAQ Replace Color plane?
uday
(5,125 Views)
CHECK ATTACHED PROGRAM.... I WANT TO CONVERT STEP BY STEP ALL BLUE TO GREEN.
IamAKR
(5,115 Views)
what does that mean - all blue to green? Do you want to swap the color channels? Or do you want to replace true blue values with true red values?
Anyway, you should use Labview native functions for optimal performance (not Mathscript nodes, which are actually really slow...). (I've also put the numeric constants outside the for loops - not because of performance, but readability).
You need to explain in more detail what are you trying to do?
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,104 Views)
