Machine Vision
CC1 triggering
Do you have an code sample (preferably in C++) that shows how to do CC1 triggering using NI-IMAQ libraries with the 1429/1430 PCI Express board?
(4,339 Views)
Can you elaborate a little bit on what exactly you mean by cc1 triggerring?
(4,331 Views)
Using the CC-1 line on a camera such as a Princeton 4K Megaplus.
(4,315 Views)
Hello dzien,
You cannot directly toggle the camera control lines using NI-IMAQ functions. You can route external trigger signals to the camera control lines. Here are two knowledgebase articles that have useful information on camera control lines:
IMAQ Boards that Support Routing to the Camera Control (CC) Lines
How Can I Control the Camera Control Lines Without External Signals
I hope this helps!
Vivek Nath
Machine Vision
(4,314 Views)
Dzien,
You should be able to generate pulses as explained in the following thread:
http://forums.ni.com/ni/board/message?board.id=200&message.id=20229
Eric
(4,306 Views)
