Machine Vision
CUSTOM STEP AND CVS
I'd like to know where should i place my file in CVS if i want that the custom step that i created to be able to locate this path. my custom step use a constant path as entry and process the data from the path. Now i want to know in which folder in CVS should i place the file for my custom step to be able to locate it. if someone can help with this problem.
Best regards
Tchou
(3,630 Views)
The root folder of the CVS is C:\
If you save a file named "foo.txt" in let's say the Temp folder on the CVS, then you need to refer to it as "C:\Temp\foo.txt" to access it.
Does that answer your question?
-Christophe
(3,613 Views)
Hi Christophe,
i did as you told me to do in your last post. I just want to get precision regarding some function i used in my program. in the picture i attached below, is there a none RT function? i'm asking that because the custom step that i created works on the host computer and seem not working in the CVS.
Best Regards
Tchaou
(3,596 Views)
