Machine Vision
CVS-1458RT - ISO I/P triggered timed loop
Hi everyone,
I am developing a real-time machine vision application on a CVS-1458 RT.
What I am aiming is a timed loop that is triggered via external clock (in my case a photoelectric sensor connected to an ISO input). All examples I can find are related to DAQmx devices, nothing related to visionRIO.
Question 1: Is this the best way to construct the acquisition loop? I want it to be condition based as to free-up the CPU from continous polling. If not, wht is the best way ?
Question 2: If the above method is OK, how can I setup the input node of my timed loop in a way to implement this ?
Thank you,
Omar
(4,602 Views)
Hi Omar,
I was able to find some Vision-RIO examples in the Example Finder of LabVIEW. If you open LabVIEW and navigate to Help>> Find Examples.
In the Example Finder in the Browse tab navigate to Hardware Input and Output>> Vision Acquisition>> Vision-RIO.
(4,502 Views)
Thank you Leeroy.
I should include the example finder as a first step before coming to the forum. I regret the effort you had to put in this. Thank you 🙂
(4,483 Views)
