Machine Vision
CVS VBAI Select Inspection Failure
I have a problem with a CVS and the VBAI.
When I switch on the Select Inspection in the VBAI and start the program sometimes the Inspection stops and the VBAI window grayed out.
I built a vbai file which does nothing else then switching the inspection after 15 loops. But when it is switching the loop crashes and i got the gray window.
The Clean up and Setup States are empty, only in the Select Inspection State is only the Select Inspection Step in.
I attached the MAX Reports and a Screenshot from the gray window.
Thank ou for your help,
Sel-PL
(3,818 Views)
Does this only happen when you switch very quickly between inspections? If you were to let the inspection finish loading and run for at least 5-10 seconds (or ~10 iterations) before switching, is it fine?
Can you attach the inspections you are switching between and the "Vision Builder System Config.ini", which contains the info about the Product Select state.
Brad
(3,804 Views)
