Machine Vision
CVS lvlog
Hi friends,
I am having a problem with CVS.
The program was developed in LV 8.2.1.
The CVS operates in stand alone (startup.rtexe), but the transmission parameters of the decision are made through a remote computer. Some of the parameters are read by CVS itself in a file with extensions txt located in the same CVS, the file has changed since it was necessary to exchange certain parameters.
After the exchange occur CVS has stopped working and displays in his log the error the following:
#Date: Tue, Jan 29, 2008 4:14:09 AM
#OSName: PharLap
#OSVers: 12.0
#AppName: PH_EXEC
#Version: 8.2.1
#AppKind: AppLib
LVRT.DLL load address: 0x002DF000
If you can help me would much
Eduardo Bannwart
(3,339 Views)
Hello friends,
Who knows what can be?
My client is charging a position.
Cordially
Eduardo
(3,320 Views)
