Machine Vision
CWIMAQDisplayMapping.MapGivenRange
Does CWIMAQDisplayMapping.MapGivenRange(min,max) work correctly with SGL (float data)? I have code that works with  I16 (short) data, but if I read the same data into a SGL (float) array and call this method there seems to be no change when displaying. From the VB help files and the Vision Concepts Manual there is no mention of this not working. I am using Vision 8.6 with VC# 2005.
John A. Lively
NDE Engineer
Pratt & Whitney
(3,357 Views)
Hi, as far as I can see from Help, Mapping working with 16 bit only:
"...Sets/gets the pixel mapping policy for displaying 16-bit images with an unspecified bit depth..."
Andrey.
(3,345 Views)
