Machine Vision
CWMachineVision.SetupViewerForLineSelection.
Hi
I want to programmaticalyset the ROI of a CWIMAQViewer.
When i use CWMachineVision.SetupViewerForLineSelection(CWIMAQViewer) i have an exception thrown.
Exception : Impossible to CAST a  AxCWIMAQViewer to CWIMAQViewer
Thanks for your help
(3,884 Views)
Your function should be CWMachineVision.SetupViewerForLineSelection(CWIMAQViewer.GetCWIMAQViewer()).  That will get your viewer in the correct format.
Alex Person
NI-RIO Product Support Engineer
(3,858 Views)
Hi
Thanks for the response i will try...
Wh do we have 2 type AxcWimaqViewer which is the Active X object and the Type CWImaqViewer which is i suppose the handle of the AxCwimaqViewer
(3,853 Views)
kikou -
This is a limitation of the current .NET API, which was directly converted from Visual Basic 6.  In our upcoming release, we will have a native .NET API that should avoid many of these confusing issues.
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
(3,849 Views)
