Machine Vision
Calculator step error
Hi
I am experiencing some problems with the Calculator step in VBAI 3.0.1. It worked fine some time ago, but now I get an error, when I try to create a new Calculator step or when I want to edit an old one
"Calculator Step Error
Some components of Vision Builder AI are either missing or corrupted.
Repair your installation of Vision Builder to fix the problem."
I have tried to repair the installation, but it did not help. It has happened to me on two computers now.
Have anyone else got the same problem or know how to fix it?
Simon
LabView 8.0.1 | VBAI 3.0.1
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
(3,949 Views)
Try to remove and reinstall VBAI
Simone
Simone
(3,946 Views)
Simone is correct, the only way to fix the problem is to remove and re-installe vision builder. Just to repair or re-installe is not enough.
The same problem appears when using ver. 2.61 or 3.0 as well.
gert
(3,920 Views)
Can anyone offer an explanation as to why the files are corrupted or missing? This seems to be a common problem, and we just started experiencing it as well. We're using VBAI 3.0.1 and LabView 8.2. We've developed this error after months of error free operation.
BCE
(3,750 Views)
