Machine Vision
Calibration of NI Vision Builder
I am trying to compare measurement using 2 different calibration which are user points calibration and grid calibration. However, for the grid calibration, if I move the object that I want to inspect away from the center, the inspection step is failed, saying that "Calibration Conversion Failed". This issue does not happen when using user points calibration. What would be the reason of this issue?
Message 1 of 1
(562 Views)
