Machine Vision
Caliper returns null values
Hi all,
Actually, I want to measure the diameter (using clamp tool) the object in the image, for that I have generated this VI (NIVA_bulid.vi) through NI vision assistant, where I can get the distance between the points 1 & 2 from caliper tool.
But , when I run as vi (dreived from VisionScript.scr), the indicators Calibrated results and Caliper results shows only the zero value.
Can anybody please tell me what’s the problem in this?
Looking forward for your eagerly.
Thanks.
Prasath M,
Emmeskay Systems Solutions Pvt. Ltd.
No: 20, Kannadasan Salai,
Chennai - 600 017.
mprasath@hotmail.com
(4,358 Views)
Hello.
I have taken a look at your Vision Assistant script and images.
Actually, when I open your script in my Vision Assistant (Vision Assistant 7.1), build the LabVIEW VI (LabVIEW 7.1 Vision 7.1), and run the VI with your image files, I am able to get results!
I have attached the VI that I used to perform the action.
If the algorithm does not detect the edges, then you will see null data in the outputs. Be sure that you are selecting the same images that you were using in Vision Assistant, and you should be able to get the same data. Again, if there is null data, it is because the algorithm did not find the required edges/points.
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(4,351 Views)
Hi Colin,
I can't find any attached VI file after your message. Could you do it once again for me ?
Thanks for response
Prasath.
Prasath M,
Chennai - 600 017.
(4,344 Views)
The problem here is not related to edge finding, but to a bug in the Vision assistant !
The built vi as a flaw : the "Points In" input of the Caliper vi is connected to an empty array, instead of being wired to the "Edge Coordinates" output of the IMAQ Clamp.
(IMAQ Vision Assistant 7.0.1, W2K
CC
Chilly Charly    (aka CC)
(4,343 Views)
Hi Charly,
It's excellent, I have corrected the vi as you said, now it works perfectly.
But couldn't open your modified .vi since it's in Labview 7.1, I have only Labview 7.0. Is there any way to open higher version(7.1) .vi in lower one(7.0) ?
Anyway, I thank very much for your valuable help.
Thanks and Regards,
Prasath.
Prasath M,
Chennai - 600 017.
(4,334 Views)
Hi Prasath !
No way to read vis of a higher version number. Just remember to tell us which version you are using when you request help. Anyway, you managed to do the modification. Congratulations ;)!
Keep wiring...
CC
(4,327 Views)
Hi Charly,
Once again, I thank you for your reply.
Prasath.
Prasath M,
Chennai - 600 017.
(4,317 Views)
