Machine Vision
Call Library node says MSVCP60D.dll not found. Try reinstalling the software.
Hi all,
When i try confiure the "Call Library function Node" to a "clsernat.dll" and exit the configure pallate it says "MSVCP60D.dll is not found, Try reinstalling the software may fix the problem." But other dlls are getting linking properly and the same dll is getting linked in other PCs. Anybody knows why is this behaviour?
Logic
(3,608 Views)
Hi Logic,
The .dll you mentioned is used in camera link serial communication. It might just be that you need to reinstall the software and its drivers. I'm not sure what would cause this, but hopefully it will be easy to resolve.
Let me know if that doesn't resolve the problem,
Robert
(3,599 Views)
