Machine Vision
Camera Brand Recommendations??
  We're looking to buy a High Speed Camera.  We have a fairly large budget, think $30k+.  We want the most resolution, frame rates(about 1000fps will do), and memory possible.  But we also want it to play well with labview.
Does anyone have any recommendations on brands or cameras??
(3,517 Views)
Check the attached link  will helps you.
Select area scan type and set your fps.
Silver_Shaper | CLD
(3,508 Views)
