Machine Vision
Camera E2V AVIIVA EM2 configuration problem
I'm trying to interface the E2V AVIIVA line scan camera with IMAQ driver. As the old icd camera files are not compatible with the new e2v cameras (completeley different serial command protocol), I did new icd camera file based on the manual and I've managed to send configuration commands. Camera is working well in free run mode, but when I try to put in in the triggered mode, each time I receive nothing more than the timeout error. The LabVIEW IMAQ trigger examples also don't work, even if I set the camera to trigger mode directly in the vendor software. I am sure that I'm receiving correct triggers, as IMAQ trigger status VI returns "True" when my input signal is high. Any hints?
Software summary:
 - NI-IMAQ 4.6.1
 - LabVIEW 2011
 - Windows XP
Hardware summary:
 - E2V AVIIVA EM2 LineScan camera
 - NI PCIe-1433 framegrabber
(3,644 Views)
Hello czab,
Could you please specify the exact example VI and the parameters that you are using (a screenshot would be also nice).
Please also let me know if you made any progression.
(3,604 Views)
