Machine Vision
Camera File for TMC-9730CL
What can I do to find, request, or generate a camera file (.icd) for the TMC-9730CL by JAI/Pulnix?  I will be using it with IMAQ and am currently trying to set it up for usage in MAX.
(3,319 Views)
Hi JRaetz:
Normally, camera files can be found by using the Industrial Camera Advisor.  However, the camera you mentioned does not have a released file from NI.  You can check with the manufacturer, request a camera file at the bottom of that page, or use the Camera File Generator to create your own (the link to download it is the last link in the paragraph).  Some basic information about the generator can be found here.
Good luck!
Message Edited by A Person on 03-24-2009 09:25 AM
Alex Person
NI-RIO Product Support Engineer
(3,306 Views)
