Machine Vision
Camera Hardware Trigger
Hello all,
I am currently working on label inspection using vision.
Is it Necessary to open and close camera for each loop ? I want to configure the camera in trigger mode once and start getting snap in every trigger.
It will considerably reduce the speed of exection and also helps others
For clear understanding Please check it out the attached vi.
Waiting for reply
Thanks in advance,
Silver_Shaper | CLD
(3,487 Views)
Hey,
Have a look at the example "Triggered Grab.vi". You will find it using LabVIEWs Example Finder.
Christian
(3,440 Views)
