Machine Vision
Camera Zoom Capabilities
Does PCI-1428 can control camera zoom or focus, if so what camera should i use?
(3,336 Views)
Zoom and focus are part of the lens, not the camera, so it is unlikely that you will be able to control it through the camera with the PCI-1428.
Most likely, if you have a motorized lens, you will be able to control it using a separate serial port.
Bruce
Bruce Ammons
Ammons Engineering
(3,336 Views)
