Machine Vision
Camera driver not detected after abrupt shutdown
Hi
I am having system windows 10 professional and using LV 2014, there are 7 camera connected with it and compatible driver also installed, System running OK with current configuration but issue arises on abrupt Machine shutdown.
After every shutdown few random camera drivers are missing in Device manager(Computer). Every time i have to update the same.
want to resolve issue and need suggestion. I have also try to resolved same issue with Labview 17 and windows 10 but output fails.
(2,246 Views)
What type of cameras are you using? Can you show a screenshot of what it looks like in Device Manager before and after? What specifically do you have to do to make them show up again? What do you mean that output fails with LabVIEW 2017?
(2,212 Views)
What type of cameras are you using? : Point Grey 14S flea2 USB based.
Can you show a screenshot of what it looks like in Device Manager before and after? : Attached here.
What specifically do you have to do to make them show up again?  : Will not get camera in NI MAX for configuration.
What do you mean that output fails with LabVIEW 2017? : Compatibility test check of windows 10 and Labview 14.
(2,169 Views)
