Machine Vision
Can 9 camera with 3.0usb use in one time using NI VISOIN BUILDER AI software?
I use 9 biro longitech camera in NI VISION BUILDER AI. When i run the program, sometime it will hang and request-time out will be pop up just for camera 1 or camera 2 not all.How to solve it?
(2,299 Views)
-Is this always occurs after same time and for same cameras?
-Do they work in NI MAX separately fine or they give same error?
-Did you try changing the cables and ports and PC and still same issue?
-Try unchecking the option "Allow the Computer to turn off this device to save power" under USB Connections in Device manager.
-Some additional info: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8jKSAS&l=en-IN
-And since you are using 9 cameras, please check you have sufficient memory(RAM) and do memory calculations.
-What is the resolution you are trying to capture at and which version of labview are you using?
uday
(2,273 Views)
thnks for the reply.i use 9 camera with same brand and in one program..9 camera use to inspect 9 side in one shoot..and i use logitech biro camera..so i want to know the maximum camera that can be use in one shoot program..
(2,233 Views)
