Machine Vision
Can I Print image from VI by IMAQ?
Can I Print IMAQ-image from VI by IMAQ?
(3,106 Views)
Hey 22222,
If you are wondering if there is a specific IMAQ VI that prints an IMAQ image, then the answer is no there is not a dedicated IMAQ VI that does this. I would like to direct you to another discussion forum link called "What is the easiest way to print the image in an IMAQ window?". This might be similar to what you are looking for. There is even an example program in this discussion forum that gives you an idea about how to print an image that is found in your IMAQ window.
I hope this helps. Please let me know if you have any further questions related to this topic. Thanks and have a great day.
DJ
(3,092 Views)
thank you
(3,087 Views)
