Machine Vision
Can I make the IMAQ Tools Palette window a child window?
I know how to make an image window a child window in the parent vi, but I was wondering if there was some way to make the little window that the IMAQ Tools Palette is displayed in a child window of the parent vi so that when I move the parent vi window, the IMAQ Tools Palette moves with it.
Thanks.
(3,089 Views)
Try using the IMAQ ConstructROI.VI. This VI allows you to select which tools are available for the user to choose and the tools show up in an expanded WindDraw window. Hope this helps.
Jack Arnold
Application Engineer
(3,089 Views)
