Machine Vision
Can I use CWIMAQControlsLib (cwimaq.ocx) in LabView environment to convert Array to Image or Rotate Image at native image data type using invokenode.vi???
Hi.
I migrate from Measurement Studio 8.xx +MS Visual Studio to NI LV Developer Suit 8.6. Unfortunately there are no ArrayToImage and RotateImage function in Vision Acquisition Module (only in NI-Vision Dev. Module). Before it I use CWimaq control (cwimaq.ocx) to do it.
1. Can I use CWIMAQControlsLib (cwimaq.ocx) in LabView environment to do these operations at native image data type using invokenode.vi???
2. If it possible how to do it.
Please help. Thanks.
Sergey.
(3,111 Views)
Hey Sermin,
If you had access to the CWIMAQ ControlsLib that allowed you to do these array to image and rotate image routines, you should will have the ability to do these same routines in LabVIEW. However, if you do not have these vi's in LabVIEW, chances are when you installed the Vision Development Module to be used with Measurement Studio and Visual Studio, chances are you only installed support for Visual Studio and not LabVIEW.
So, if you re-run the installation of you Vision Development Module now that you have LabVIEW installed, you should have the ability to install support for LabVIEW. If you do not have your installation CD's but you do have your serial number, you should be able to download the Vision Development Module and install/activate it without trouble.
Hope this helps.
-Ben
WaterlooLabs
(3,092 Views)
